Used 2.0 throttle body vs. new($$$) 1.8 throttle body
Anything wrong with putting a 2.0 throttle body in a 1.8?
'00 Volvo S80
'96 Jeep Cherokee
'94 Toyota Camry
deceased '72 1.7
deceased '75 1.8
'41 HD Knucklehead (rebuilding basketcase into chopper)
'74 1.8 (Ravenna green and drivers still don't see me!)
Old 06-23-2004, 07:22 AM
914 Geek
Will it even fit? I don't remember if the attachments are the same or not.
Make sure you use the throttle position switch from the 1.8 TB, as the 2.0 (D-jet) ones are quite different.
--DD
Old 06-23-2004, 09:40 AM
rockaria's Avatar
I have an extra used/working fine throttle body from a 1.8 if you are inetrested?
Christopher A. Landt
1979 911sc
1973 914 2.0
Old 06-23-2004, 09:49 AM
Dave, you're right again - they're not exactly the same outlet size but I figured a little bit of minor engineering and I could make it work. I'll check the tps.
Christopher, mine is OK with the exception of the butterfly plate sticking in the closed position which makes for unsmooth gas pedal action. If yours doesn't do this, I'm interested. How much?
'00 Volvo S80
'96 Jeep Cherokee
'94 Toyota Camry
deceased '72 1.7
deceased '75 1.8
Old 06-23-2004, 01:49 PM
rockaria's Avatar
Nope, mine sticks just a bit.
Sorry,
1979 911sc
1973 914 2.0
Old 06-23-2004, 01:53 PM
mike mueller's Avatar
no need to purchase a new 1.8 t/b.....tons of decent used ones out there....(I've got a few myself if you cannot find one local)
the 2.0 t/b's mount to the plenum with a flat to flat mating
the 1.8's have a rounded fitting on the plenum and a strange rubber gasket. You'd have to machine the inside of the 2.0 t/b to get it to have the proper radius for sealing.
are you sure it's the t/b and not the TPS that is causing the sticking??
'73 914, 1.7, with Boxster transmission in the future?
Old 06-23-2004, 08:24 PM
Mike - yeah, I'm positive about the cause of the sticking. It's the brass butterfly plate chewing into the bore of the t/b. There's even a rough groove worn into the bore. The reason it does this is because there is no stop designed into the body for the butterfly valve to rest against at 100% closed. The slightly angled edge of the plate itself acts as the stop. Poor design. If you have one that doesn't dig in, I'm interested.
'00 Volvo S80
'96 Jeep Cherokee
'94 Toyota Camry
deceased '72 1.7
deceased '75 1.8
Old 06-24-2004, 06:31 AM
