how to install copper gaskets? on the headers?
pics? and how many pounds of pressure on the nut 16?
where is the nut how...!!!!!!!!!!!!!!
Blue 73' 914 1.7 |
You forgot to say the magic word.............................
914 Geek
You just take the heat exchangers off the heads (OK, that leaves out a lot of swearing and spraying with Aero Kroyl and possibly breaking exhaust studs and more fun stuff like that), pull the old gaskets out, put the new ones up in the recess at the exhaust port, and keep them in place while you put the exchangers back on.
I have seen high-temp RTV used to hold them, just at the edges. It only has to hold for as long as it takes to get the exchanger on. I usually push them in place and then rotate them a bit, which usually works about half the time. Sometimes I get the exchanger sitting on the studs (no nuts installed) and then have to put the gaskets back in again around the heat exchanger tubes. I forget the torque setting for the exhaust nuts, but it's not very high! Check your Haynes. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Take a file to the top of the header tubes and flatten them out. Leave the file marks to 'bite' into the copper.
914 Geek
Use a file that is large enough that you get both tubes at once. They must be flat and straight relative to each other.
--DD
what if i have the original studs on there what do i use to get the rust off and so i can screw on new nuts and if it wont work where can i buy new studs
Blue 73' 914 1.7 |
