Sway Bar bushing install
I got new sway bar bushings for my car to replace the missing one and the very old one that is already on there. I cannot get them in, I have tried grease, WD40 and even heated them up with a heat gun with no luck so far. Anyone have any tricks for installing these? Then, once I get them into the holder, any tricks on pushing them on the sway bar bolt? I am out of ideas.
http://www.pelicanparts.com/gallery/skline It's easier to get forgiveness than it is to get permission. 75 Slantnose V8 03 S-10 Extended cab stepside in Yellow 72 914 Parts car |
I warm them up, lube'em with silicone grease, then use a big C-clamp to squeeze them on.
I used a vise and a rubber mallet, but Guy's idea with the C-clamp sounds easier.
Kent '73 914 - Suby 3.3L conversion '99 996 - For sale ($22K) |
914 Geek
Yup, C-clamp. Or vise. You may have to poke at it in spots with a screwdriver or other similar implement.
I use a bar clamp to install the drop-link on the car. It can be a little tricky, though. I usually put the one corner of the car in the air, then use a jack to move the trailing arm up until the ball stud position matches the drop-link position. Then squeeze it on with a clamp. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
