Question 2.0l vs 2.0l Whats the difference
Ok what is the difference between a bus 2.0l and a Porsche 2.0l??
Also what is the largest relible size I can go to if I rebuild the Bus 2.0?
Mark
Old 01-16-2005, 02:08 PM
Banned
Alfred1's Avatar
Should find your answers here http://www.tunacan.net/t4/reference/case.htm .
Old 01-16-2005, 02:16 PM
grind weld build
sean_V8_914's Avatar
good link, thanks
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 01-16-2005, 06:57 PM
Thanks. Now I need to look at the numbers. What would be the largest I could build the bus motor??
Mark
Old 01-16-2005, 07:43 PM
914 Geek
3 liters plus. Bring money--cubic money.
You can build any displacement Type IV engine on any Type IV case. Some need a little more work for some applications (e.g., you have to block off the oil filler/dipstick hole in a Bus case to use it in a 914), but you can base your engine on just about any crankcase.
Going beyond ~74mm stroke requires quite a bit of work. Going beyond ~96mm bore can be done without a lot of work (and won't last), or with a lot of work (and will last a little bit) or a massive cash infusion for Nikasil-plated aluminum cylinders (and will probably last reasonably).
For a ton of info (and some propaganda), see http://www.aircooledtechnology.com .
--DD
Old 01-16-2005, 09:30 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Re: 2.0l vs 2.0l Whats the difference
Mark
Short answer?
Heads, Flywheel, Sheet Metal, Pistons, Valves, Crank are all different.
Basically, the case is the same... Except the dipstick is in a different location..
Bus 2.0L's wil need a lot of work to make them large and reliable..
Aircooledtechnology.com
Jake Raby is the Shonuff' of the Type 4
Old 01-18-2005, 12:05 AM
COLDBASS's Avatar
Quick dicking around. You know that you want to go "six"...
923/912E (2.1l OEM EFI
'99 F150 4x4 Chipped (who cares)
LLVL in the LBC...
"Long Hoods Rule"
"RICE - The Breakfast of Champions"
Old 01-20-2005, 03:37 PM
Your Right. You got one cheap?
Old 01-20-2005, 09:27 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Mark
Scott is pick up a 3.0 that he maybe selling.
I will be looking at it over the weekend .Its a fresh rebuild but its in peices but I will assemble it. Give him a call.
Old 01-21-2005, 06:25 AM
COLDBASS's Avatar
As soon as the GF discovers that I have more than 2 Porsches, I will probably be "influenced" into selling something...either that or buying her that damn "Wolf" stove...too bad she doesnt know how to cook..
Why dont you hook up with L. Jones and buy his neighbors '70 or 71 (?)...I think that the gent grew tired of the project and wants to unload. I guess the the motor is pieces (4 cyl)...I thought he said $1k. Put a six that one...
LLVL in the LBC...
"Long Hoods Rule"
Old 01-21-2005, 06:04 PM
I'll check with them
Thanks Steve and Bob
Old 01-22-2005, 11:04 AM
