Andyrew's Avatar
CV's, how to take them off?
Since the club site is down, im resorting to here!!!
Havent been here for a while..
Anyways, The cv/half shafts...
The trani side is simple.. unbolt..
The wheel side, do you have to take the big ars nut off?? ie with a 300lb or so breaker bar?
broke mine in my v8...
First time! once i get it fixed im going to do my first burnout and my first dougnut! then if it breaks again, I know that its the problem and I need to get better ones!!!
Andrew
Old 02-09-2005, 06:01 PM
skline's Avatar
Well, you will need bigger ones I can promise you that. Anyway, you can get it out without removing the stub axle, you have to unbolt it and then use the axle like a puller. They have been in there a long time but they will come off. Good luck Andy.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 02-09-2005, 06:17 PM
Acox914's Avatar
Send a message via AIM to Acox914
same 12 point tool, on a socket..... with an extension.....
at least you dint break your tranny./.....yet
-Aaron
"60% of the time, it works every time"
Old 02-09-2005, 06:44 PM
skline's Avatar
I broke 2 sets of CV's with a modified 1.7 liter many years ago. So I know your V8 will tear them apart. You could start the cheap way, use Bus axles and CV's with an adapter. It will be as strong as using ones from a 911. Just a thought.
75 Slantnose V8
72 914 Parts car
Old 02-09-2005, 06:48 PM
Acox914's Avatar
go 930's, all the high HP sandrail guys do
-Aaron
Old 02-09-2005, 06:57 PM
grind weld build
sean_V8_914's Avatar
you can do V8 burn outs all day long without breaking CVs. DO NOT SIDE-STEP THE CLUTCH. from a rolling start, with clutch fully engaged, roll into teh gas pedal 1/2 way them floor it but no stomping. add a little brake and watch em bake. watch your tach! Grove st is still tatooed after all teh rain. no one leggers here!
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 02-09-2005, 08:41 PM
