914 914 is offline
914's Avatar
Question Is Alternator Hard To Change?
Mine is making bearing noises,Its been in the car for 35 years. Its looks like a bear to get at.....
Take Care,914
Old 03-01-2005, 05:44 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
easy. access is from under car. somewhat basically, but refer to repair manual for complete procedure:
loosen belt
remove piece of engine tin
disconnect wiring
unbolt alt
installation is reverse
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 03-01-2005, 06:36 AM
Banned
Alfred1's Avatar
Will the alternator from a '75 1.8L fit a '73 2.0L?
Old 03-01-2005, 08:57 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Yes, the alternators for the four-cylinder 914s are all the same.
Check the Tech Articles for a slightly more detailed version of how to replace the alternator.
http://www.pelicanparts.com/techarticles/914_alt_replace/914_alt_replace.htm
No pics, sorry! I didn't have a digital camera at the time.
--DD
Old 03-01-2005, 09:32 AM
SGB SGB is offline
SGB's Avatar
a valuable first step is to climb under and spray all those screws on the cooling tin with wd-39 or equivilent a few times over a couple of days prior to tackling the job. Also, get some spare 10 mm ( i think ) machine screws fer the tin. Don't forget about the 10mm bolt reached from over the engine that is between the alt and the fan holding the tin to the engine case.
-Scott
My gallery page
Old 03-01-2005, 07:48 PM
