skline's Avatar
FI Problem
Its the fuel pump, it wont come on. I have installed a known good fuel pump, checked the relays but I am not getting power to the fuel pump. What could it be? Any and all valid suggestions will be checked. Help me here, the club board seems to be having problems.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 06-01-2005, 07:31 PM
Headrage's Avatar
You probably already did this but maybe fuse on relay board???
Old 06-01-2005, 07:32 PM
bowlsby's Avatar
Cool
Check out Brad Anders FP page Scott...
http://members.rennlist.com/pbanders/FPChecklist_frame.htm
Old 06-01-2005, 07:35 PM
skline's Avatar
The front page looks great but doesnt go any further. So that is not going to help me much. Allen, Of course I checked all the fuses. Anymore ideas? I hooked up power to the FP and it started. I found a leak in an injector on the drivers side so I shut it off. The car does run. I have everything to make it good, I just need a little direction.
75 Slantnose V8
72 914 Parts car
Old 06-01-2005, 07:48 PM
914 Geek
Bummer. We'll have to ping Brad about getting his flowcharts working again.
A different take at the diagnosis (in text form) can be found here:
http://www.914fan.net/fuelpump.html
--DD
Old 06-01-2005, 07:54 PM
tneffhoe
Guest
Posts: n/a
Are you getting the fuel pump to run right when you turn the key? Relay board is what I would check. I am sure you have a spare around, or pull from another car for a quick test.
Old 06-01-2005, 08:41 PM
skline's Avatar
Yup, got spares. I will screw with it tomorrow. I hooked up power to the fuel pump and it started right up but there is a leak from the injector on number 1.
75 Slantnose V8
72 914 Parts car
Old 06-01-2005, 08:59 PM
bowlsby's Avatar
Brads page works for me...?
Old 06-01-2005, 09:36 PM
skline's Avatar
It was a browser problem. I had to open it with IE instead of Moz.
75 Slantnose V8
72 914 Parts car
Old 06-02-2005, 05:46 PM
914 Geek
Ick! IE??
I do know that it worked for me under an earlier version of Netscape quite a few years back...
--DD
Old 06-04-2005, 03:43 PM
