Guess the part contest! Huge Prizes!
Ok well, its been a bit slow around here...
Its time to play guess the part! First to correctly guess gets the set of parts in 18-8 stainless steel! Ooooohhhhhh.....Ahhhhhhhh.... M4 Size Length 8mm with a 7mm Pitch. Most cars I have seen have 4 in the set. One had just 2 with the other 2 slightly longer. Where do they go? Shows one OEM and the stainless one.
...and DD cant play because he is the sum of all knowledge 914...
screw that holds on rear rotor
We'll be having an ISO9000 audit soon. I've divided our preparation tasks into two groups: Unethical and Unproductive. |
Good guess! but those are longer...
914 Geek
I've got a guess. Mixing up the longer and shorter ones leads to really weird problems, right? (Guess how I know that...)
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Inside door handle screw?
Another solid guess.
The door handle is 900 147 004 02 an m5 screw gettin warmer... |
914 Geek
Rats, that was my guess! Hmm... M4? The ones of those that are coming to mind are slot-head screws, not phillips-head. Hrrr....
Let's see, phillips-head, M4, for a countersunk hole.... Hmmmmmmm.... --DD
It's the screw that holds the trim around the inside door handle.
If its too long, it jams the handle.
Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga) |
yeah but he said there are 4 in a 914....
According to Google, "I" am Mike Mueller ![]() 1974 914 with 72 1.7 and 74 L-Jet system (vroom) |
window track screws?
"not an expert, but I play one on message boards" |
VERY close goose2
gonna have to be a bit more specific. |
Lower dash cushion? Pete
Side mirror screws
76 914 2.0 (critical condition) 73 914 1.7 (new project) 04 Pontiac Aztek (parts hauler) |
!!! its the 2 window handle screws and the 2 inside door screws
bingo!
-Aaron "60% of the time, it works every time" |
914 Geek
I thought the mirror screws were larger than that. And there are more than 4 on a 914; there are two holding the mirror on (and may be two more on some cars), plus two more (I think) holding each of the door latches or strikers on. (Forget which at the moment.)
--DD
The side mirror screws are much larger panheads.
914 531 523 10 Raised Head M6 x 12 Hint: You can only see two of them without a teardown. They are on the door. |
the ones on the bottom of the door, that adjust the top of the window in or out....
you know...
Sorry...those are bolts and nuts
