Post
(looking in the wallet) Hmm, flycut the 1.7's.... Thanks for the advice.
-Kevin
Originally posted by JP Noonan:
They were and should still be slip ins. However, the big bore 1.7L are notorious for head leaks even if you don't use haed gaskets and instead lap the cylinders. The better way is to
1. Flycut the 1.7L heads to accept the 1.8L BB kit. or even better
2. Buy some 1.8L heads which have bigger valves and use the 1.8L kit.
OTTOMH thw 1.7L heads have 39.3mm intake and 33mm exhaust while the
1.8L have 41mm int and 34 exh.
The 914 2.0L have 42mm int and 36mm exh.
and the 2.0L bus heads have 37.?mm int and <33mm exh (that is one reason they suck).
[This message has been edited by Kevin@ojai.net (edited 07-04-2001).]
Old 07-04-2001, 12:00 PM
