Post tranny rebuild questions
What is the average cost of rebuilding a transmission?
Cost of someone supplying a rebuilt transmission?
Are trannys more intense to rebuild than engines?
Old 08-30-2001, 12:49 PM
Unregistered
sammyg2's Avatar
Post
I rebuilt mine, not all that expensive. I replaced three syncros, one bearing, and all seals (from pelican).
Only problem is, setting the gear backlash and bearing pre-load requires some unusual tools.
Unless you are very experienced with manual transmissions and/or differentials, leave it to an expert.
A decent transaxle can usually be found for around $250 in the junk yards, but will probably need a first and maybe a second gear syncro. No guaranties.
Gerald Gore II (Sam)
73 914 350 small block
Old 08-30-2001, 06:22 PM
