ddustan's Avatar
Question How to Adjust Window Roll-up Height?
How does one adjust the height which the 914's windows will roll up to? I think I may have enough seal if the windows will get up to them!!
Old 08-31-2001, 06:09 AM
ShawnO
Guest
Posts: n/a
Post
Gently unsnap the pins that hold the door panels on(after removing the window crank, inner door latch and pull handle) You'll see the window crank assembly. You'll notice a bolt with a nut on the assembly. It the sets the distance your window can roll up. It's pretty obvious after you take the door panels off. I think this is for the '73 and later cars only. I don't know about the earlier ones.
Old 08-31-2001, 07:39 AM
green71's Avatar
Post
Earlier cars have a couple of screws (or are they bolts?) on the underside of the door toward the front. One adjusts the angle of the window, and the other adjusts the roll-up height.
Mark
1971 1.7l 914
Old 08-31-2001, 12:17 PM
ddustan's Avatar
Post
Thanks Shawn and Mark! I'll take a look at the doors today. Appreciate the help!
David Dustan
'74 914 1.8
Old 09-01-2001, 09:07 AM
