Web-Cam
Hey guys. I'm in the proccess of rebuilding my engine and buying the various parts. I'm planning on getting a web-cam, but I'm tempted to get the performance cam. It says this cam is specifically designed for carbs. Before (and or if) I switch to carbs it will have to be awhile after I build the engine. Will this performance web cam have a negative effect if I use it with my stock fuel injection. Will it wear grooves in my cam or anything to that effect? Thanks ;D
73 914 2.0
Old 09-26-2001, 02:55 PM
914 Geek
Porsche Crest
It will not wear holes in the cam, but the car will either run like crap, or it won't run at all. The carb-oriented cam will drastically change the vacuum characteristics of the engine, which is what the FI depends on to figure out how much fuel to inject. While you can tweak and adjust the EFI to some extent, you can't adjust it enough for it to run decently with a very lumpy cam.
--DD
Old 09-26-2001, 04:14 PM
Post
Hmm, interesting, thanks for you reply Dave. Lets say I turn the senario around and put on the non-performance web-cam and ran that with my stock FI. And then if I eventually want to convert to carbs, will that inverslly have any negative affects on the non-performance web-cab with carbs? Thanks
73 914 2.0
Old 09-26-2001, 04:34 PM
DDS DDS is offline
Post
How 'bout non-performance? If you leave the cam, leave the D-jet.
Old 09-26-2001, 05:26 PM
DDS DDS is offline
Post
Gotta watch those glib replies - shouild have said 'unexploited potential'.
Dave
Old 09-27-2001, 08:07 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
While rebuilding the motor in my daily drive I installed a Stock 2.0 FI cam motor,I put the Twin 44 Webers on it with a little tuning I got it to run fine. 009 set @ 32 btdc, 135 main ,55 ilde, 170 air. Steve
Old 09-27-2001, 09:59 AM
