Web-Cam
Hey guys. I'm in the proccess of rebuilding my engine and buying the various parts. I'm planning on getting a web-cam, but I'm tempted to get the performance cam. It says this cam is specifically designed for carbs. Before (and or if) I switch to carbs it will have to be awhile after I build the engine. Will this performance web cam have a negative effect if I use it with my stock fuel injection. Will it wear grooves in my cam or anything to that effect? Thanks ;D
------------------ 73 914 2.0 |
Administrator
It will not wear holes in the cam, but the car will either run like crap, or it won't run at all. The carb-oriented cam will drastically change the vacuum characteristics of the engine, which is what the FI depends on to figure out how much fuel to inject. While you can tweak and adjust the EFI to some extent, you can't adjust it enough for it to run decently with a very lumpy cam.
--DD ------------------ Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Hmm, interesting, thanks for you reply Dave. Lets say I turn the senario around and put on the non-performance web-cam and ran that with my stock FI. And then if I eventually want to convert to carbs, will that inverslly have any negative affects on the non-performance web-cab with carbs? Thanks
How 'bout non-performance?
Author of "101 Projects"
No, it shouldn't. The standard grind works well with FI or carbs. If you know what you're going with though, you can get a more aggressive grind to match your fuel delivery method. If you're not sure, then go with the standard grind...
-Wayne |
Gotta watch those glib replies - shouild have said 'unexploited potential'.
Dave |
Banned
While rebuilding the motor in my daily drive I installed a Stock 2.0 FI cam motor,I put the Twin 44 Webers on it with a little tuning I got it to run fine. 009 set @ 32 btdc, 135 main ,55 ilde, 170 air. Steve
Thread Tools | |
Rate This Thread | |
