speedemon666's Avatar
Knock, Knock
Says my rear suspension.
I hear this when I'm turning right but not left. Sends a chill down my back to hear it.
Looked under the 914 and didn't see anything obvious. Grabbed the axle shafts and both are able to slide in/out about an inch.
Could this my problem?
Old 02-22-2009, 07:59 PM
Hi Speedemon,
Just want to say that its not just you or your car.
I have started driving mine around again recently and sure enough, it makes a heavy thump or knock only when turning right.
Cant wait to see what it is.
Anyone know what it is?
Curt
Old 02-23-2009, 03:13 PM
Max Sluiter
Flieger's Avatar
On a 911, the suspects would be broken rear sway bar mount, worn constant velocity joint, and then worn/loose wheel bearing.
Old 02-23-2009, 09:49 PM
My initial thought (and still is) was the CV Joints.
Do your axles slide around like mine?
Old 02-23-2009, 09:52 PM
Otto's Avatar
knock
It is your cv joints, we see it all the time.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 02-24-2009, 04:41 PM
Ok, there's the answer from someone in the biz. Thanks Otto.
If its the CV joints causing the thump, does that then mean the CV joints are bad?
Curt
Old 02-24-2009, 08:41 PM
Thank You Mr. Otto, your input is greatly appreciated.
Old 02-26-2009, 12:04 AM
Otto's Avatar
cv's
They should be taken apart and inspected for wear marks/cracks. Nobody ever repacks these when servicing the rest of the car. We do. There is a CV joint grease that should be used. It is less expensive to buy the complete axle assembly than the individual pieces.
Old 02-26-2009, 03:16 PM
Hmm,
I think it's time to find a new mechanic.
Old 02-28-2009, 07:14 AM
I am not sure about Speedemon's problem but Curt914, mine was doing a single thump or knock every time I made a hard right turn which turned out to be a busted trailing arm bushing. If that's the case with yours, you better get to it quickly. I replaced mine with the aftermarket bushings, which I lubed with a special grease I got from Otto. 3+ years and 40k miles later, still no binding or squealing.
Good luck
PS, no need to burn the old bushings out like some people suggest. I used a hydraulic press and they popped right out.
Old 03-08-2009, 09:43 PM
rymann's Avatar
i had a 71 years ago the did that very thing and it ended up being the sway bar mount was loose, there was no obviouse sighns of it being loose until i put a wrench on it and tightened it up soon as i did that problem solved ,good luck
Old 03-21-2009, 10:43 PM
