Dixie Region R Gruppe
w21055's Avatar
914 strut inserts work with 911 struts
Hey guys. I want to ask before I start tearing the car apart.
I bought a 84 Carrera front end for my 74 914. The strut inserts from the 911 are pretty much shot so I wanted to know if I could put the inserts out of my 914 struts in the Carrera struts since they are fairly new. I searched and ran across answers from no to yes or yes depending if you can get the right nut (don't recall exact name) Flange nut I think.
Phillip
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 10-20-2009, 06:06 PM
tat2dphreak's Avatar
on the early(70-73) boge struts you can use any 914 strut insert, but on the later struts, you have to use the 911 they were designed for as far as I know... bilstein inserts for bilstein struts, koni for koni. boge uses any
'72, now with a living, breathing 2056...
Old 10-21-2009, 08:31 AM
w21055's Avatar
Ok thanks. Was hoping for the cheap way out, I thought 914's were cheap :^).
1992 Ferrari 348TB
Old 10-21-2009, 05:28 PM
they are, you are using a 911 part tho
Old 10-21-2009, 08:22 PM
