Rocker Panel Rivet Size Question
Can someone tell me what size rivets are used on the rocker panels?
Are they plastic? Is a hand rivet gun good for installing them? Thanks. |
Been years since I replaced any and therefore forget the size. I used Stainless Steel though since RUSTing was a potential concern. Hand gun worked fine.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Administrator
The stock ones are black plastic. I have heard of people getting the (more common) white ones and soaking them in ink to turn them black before installation. I do not remember the size.
The factory catalog just calls them "expansion rivet", with a part number of 999.591.550.40 . --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I use small screws instead of the rivets. People always say to check behind the rockers for dirt and debris then mount the rockers with a fastener which isn't easily removed.
Can't tell the difference between the screw head and rivet. |
1976 914 2.0 Original Owner - 24,000 miles 1989 911 Carrera 4800 miles |
