-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   The Last New 914-6 GT Project (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/632760-last-new-914-6-gt-project.html)
ajserrano 02-20-2012 11:22 AM
Cont....
FAST-FORWARD PHOTO!
http://forums.pelicanparts.com/uploa...1329973988.jpg
...now back to the fab work...
http://forums.pelicanparts.com/uploa...1329768869.jpg
http://forums.pelicanparts.com/uploa...1329768882.jpg
http://forums.pelicanparts.com/uploa...1329768928.jpg
http://forums.pelicanparts.com/uploa...1329768947.jpg
http://forums.pelicanparts.com/uploa...1329768965.jpg
http://forums.pelicanparts.com/uploa...1329769004.jpg
drilling the new attachment bolt holes at the rear of the Scheel GT seat rails...
http://forums.pelicanparts.com/uploa...1329769029.jpg
making sure there is enough clearance for the hinged bracket to work properly...
http://forums.pelicanparts.com/uploa...1329769047.jpg
http://forums.pelicanparts.com/uploa...1329769069.jpg
ajserrano 02-20-2012 11:39 AM
Cont...
Random Photo - Ex-Kremer 914-6 GT
http://forums.pelicanparts.com/uploa...1329974456.jpg
A few of the photos below are a bit out of sequence since they show the GT Rally Hand-Brake Reinforcement already finished. I'll post the photo sequence for the GT Rally Hand-Brake a bit later, after completing this particular section of the GT seat-rail project.
http://forums.pelicanparts.com/uploa...1329770052.jpg
http://forums.pelicanparts.com/uploa...1329770067.jpg
When welding at the top of the floor pan...
http://forums.pelicanparts.com/uploa...1329770087.jpg
...this is what happens on the opposite side...
http://forums.pelicanparts.com/uploa...1329770104.jpg
http://forums.pelicanparts.com/uploa...1329770123.jpg
...and repairs have to be made.
http://forums.pelicanparts.com/uploa...1329770137.jpg
http://forums.pelicanparts.com/uploa...1329770153.jpg
http://forums.pelicanparts.com/uploa...1329770168.jpg
http://forums.pelicanparts.com/uploa...1329770188.jpg
ajserrano 02-20-2012 11:45 AM
Cont...
http://forums.pelicanparts.com/uploa...1329975088.jpg
http://forums.pelicanparts.com/uploa...1329770592.jpg
http://forums.pelicanparts.com/uploa...1329770604.jpg
http://forums.pelicanparts.com/uploa...1329770617.jpg
http://forums.pelicanparts.com/uploa...1329770632.jpg
http://forums.pelicanparts.com/uploa...1329770646.jpg
http://forums.pelicanparts.com/uploa...1329770659.jpg
http://forums.pelicanparts.com/uploa...1329770672.jpg
http://forums.pelicanparts.com/uploa...1329770686.jpg
http://forums.pelicanparts.com/uploa...1329770700.jpg
ajserrano 02-20-2012 11:53 AM
Cont...
http://forums.pelicanparts.com/uploa...1329975382.jpg
http://forums.pelicanparts.com/uploa...1329770902.jpg
http://forums.pelicanparts.com/uploa...1329770922.jpg
http://forums.pelicanparts.com/uploa...1329770934.jpg
Checking the adjustment lever angle to insure they're all formed the same...
http://forums.pelicanparts.com/uploa...1329770958.jpg
http://forums.pelicanparts.com/uploa...1329770986.jpg
http://forums.pelicanparts.com/uploa...1329771002.jpg
Trial fitting the Scheel racing bucket...
http://forums.pelicanparts.com/uploa...1329771016.jpg
http://forums.pelicanparts.com/uploa...1329771030.jpg
Machining aluminum spacers for the front attachment points of the GT Scheel seat rails...
http://forums.pelicanparts.com/uploa...1329771044.jpg
ajserrano 02-20-2012 11:56 AM
Cont...
The #69 Max Moritz built 914-6 GT
http://forums.pelicanparts.com/uploa...1330111788.jpg
http://forums.pelicanparts.com/uploa...1329771258.jpg
http://forums.pelicanparts.com/uploa...1329771270.jpg
http://forums.pelicanparts.com/uploa...1329771282.jpg
http://forums.pelicanparts.com/uploa...1329771294.jpg
http://forums.pelicanparts.com/uploa...1329771307.jpg
http://forums.pelicanparts.com/uploa...1329771323.jpg
http://forums.pelicanparts.com/uploa...1329771334.jpg
http://forums.pelicanparts.com/uploa...1329771350.jpg
http://forums.pelicanparts.com/uploa...1329771362.jpg
ajserrano 02-20-2012 12:07 PM
Cont...
The 04 entry of VanLennep-Marko, a Porsche 908-3 at the 1971 Nurburgring. I'm not sure which 914-6 GT is the one car behind it.
http://forums.pelicanparts.com/uploa...1330112106.jpg
Checking measurements to insure the upper rails are not only parallel to each other, but also spaced correctly so that they can slide front-to-back
easily when the seat assembly is mated to the lower rails. Any misalignment here will definitely create a binding mechanism.
http://forums.pelicanparts.com/uploa...1329771447.jpg
I can't stress enough how important it is to have the correct rail alignment prior to permanently welding the two rear seat rail support brackets.
http://forums.pelicanparts.com/uploa...1329771472.jpg
http://forums.pelicanparts.com/uploa...1329771483.jpg
http://forums.pelicanparts.com/uploa...1329771497.jpg
http://forums.pelicanparts.com/uploa...1329771509.jpg
http://forums.pelicanparts.com/uploa...1329771523.jpg
http://forums.pelicanparts.com/uploa...1329771539.jpg
http://forums.pelicanparts.com/uploa...1329771552.jpg
...and the finished product, primered and ready for paint.
http://forums.pelicanparts.com/uploa...1329772214.jpg
ajserrano 02-20-2012 12:32 PM
The 914-6 GT Rally Hand-Brake Modification
As I've done before, I'll start this section of the project with a few sample photos of how the Porsche factory relocated and modified the parking lever mechanism for the Rally cars. Take a look...
1970 Porsche sn 914.043.1948 and more detailed photos of the GT can be found here
http://forums.pelicanparts.com/uploa...1329773360.jpg
http://forums.pelicanparts.com/uploa...1329773371.jpg
http://forums.pelicanparts.com/uploa...1329773382.jpg
http://forums.pelicanparts.com/uploa...1329773394.jpg
http://forums.pelicanparts.com/uploa...1329773410.jpg
http://forums.pelicanparts.com/uploa...1329773424.jpg
http://forums.pelicanparts.com/uploa...1329773435.jpg
The rather large diameter cable in the photos below actuates a modified 'drum-brake' mechanism that was incorporated at the rear hubs of the 914-6.
Unfortunately, I don't have any other detailed photos of the 911-type drum brake setup in the 914-6 GT rally cars.
If by chance you know anyone that can contribute photos of this section of the GT, please email them to me at ajserrano @ msn dot com.
(you can figure out my my exact email address, right?).
http://forums.pelicanparts.com/uploa...1329773454.jpg
http://forums.pelicanparts.com/uploa...1329773465.jpg
http://forums.pelicanparts.com/uploa...1329773475.jpg
ajserrano 02-20-2012 12:33 PM
Cont...
Unknown 914-6 GT interior photo...
http://forums.pelicanparts.com/uploa...1330112561.jpg
...Here are two more photos of the same factory built 914-6 GT as shown on previous post.
http://forums.pelicanparts.com/uploa...1329773619.jpg
http://forums.pelicanparts.com/uploa...1329773630.jpg
The following photos were provided by Wilco of Germany.
Wilco Halves modified the rear trailing arms of a 914 to accept the 911 drum type brake mechanism.
I believe the Porsche factory implement a similar installation in their Rally prepared 914-6 GT race cars,
but I have yet to confirm details of the installation.
http://forums.pelicanparts.com/uploa...1329777687.jpg
http://forums.pelicanparts.com/uploa...1329777703.jpg
http://forums.pelicanparts.com/uploa...1329777715.jpg
http://forums.pelicanparts.com/uploa...1329777733.jpg
http://forums.pelicanparts.com/uploa...1329777746.jpg
http://forums.pelicanparts.com/uploa...1329777757.jpg
ajserrano 02-20-2012 12:59 PM
The Monte Carlo Rally 914-6 GT sn 914.143.041
A few sample photos of yet another very famous Porsche factory built 914-6 GT rally car. For more detailed photos of this particular GT, go here
Armin Knüpfing of Knüpfing Motorsport (sitting closes to the 914-6 GT) is the individual responsible for the very accurate and recent restoration of this vehicle.
http://forums.pelicanparts.com/uploa...1329773845.jpg
Top view of the relocated purposely modified GT rally hand-brake mechanism.
http://forums.pelicanparts.com/uploa...1329773858.jpg
...and the following are photos of the bear chassis while the GT was being restored, it shows this section in greater detail.
Please ignore the rectangles highlighting the Rally GT seat-rail brackets, what I'm actually trying to show in the photos below is the GT parking-brake reinforcement.
http://forums.pelicanparts.com/uploa...1329774641.jpg
http://forums.pelicanparts.com/uploa...1329774654.jpg
http://forums.pelicanparts.com/uploa...1329774668.jpg
...and a "flash-forward comparison photo" of my 914-6 GT along side the factory installed modification.
http://forums.pelicanparts.com/uploa...1329774773.jpg
Here is a more detailed top-view photo of the 914-6 GT Rally Hand-Brake Reinforcements modification installed in my GT project.
http://forums.pelicanparts.com/uploa...1329772225.jpg
ajserrano 02-20-2012 01:18 PM
Monte Carlo / Marathon de la Route Porsche 914-6 GT sn 914.043.0983
A couple of photos of one more factory built 914-6 GT that has the rally hand-brake modification. Take a look here for more detailed photos of this significant GT
http://forums.pelicanparts.com/uploa...1329776208.jpg
...a poor photo, but note the pawl mechanism that engages the brake ratchet.
http://forums.pelicanparts.com/uploa...1329775781.jpg
Pete000 02-20-2012 06:33 PM
I see a problem with your build.
Your quality and craftsmanship is much much better than the factory !
I think you need to dull your tools and hurry up and be much more sloppy to be more true to the factory work.
Ha ha ! Very impressive build !
ajserrano 02-20-2012 07:22 PM
Quality Control Dial...
Hello Pete. You're so right, the Porsche factory, at that time, never really cared or meant to work on their race cars at this quality level.
Having said that, production cars are a whole different story, where workmanship always shines. ;)
I joked around with Mark (the guy responsible for all the fabrication work and talent) threatening him with the installation of some sort of "dial-implant" where
one would have some level of "quality control". Using the dial, I could back him off a bit on certain areas of the project where I don't want things to look so perfect.
Trust me, I'm by no means complaining... :D Thanks for the post!
PORSCHE 993 PROMOTION (Part 1)
<iframe width="640" height="480" src="http://www.youtube.com/embed/guDH-OQqJkQ?rel=0" frameborder="0" allowfullscreen></iframe>
<iframe width="640" height="480" src="http://www.youtube.com/embed/hBUCFBI_ggQ?rel=0" frameborder="0" allowfullscreen></iframe>
<iframe width="640" height="480" src="http://www.youtube.com/embed/0y0ODCjqJzE?rel=0" frameborder="0" allowfullscreen></iframe>
1971 Le Mans - The #19 Porsche 917K of Atwood-Muller
http://forums.pelicanparts.com/uploa...1330112850.jpg
ajserrano 02-21-2012 04:51 PM
Upcoming New 911 RSR DVD Release...
Here is a short video trailer of an upcoming 911 RSR DVD release.
I have a longer version but not allowed to post it anywhere... Check it out!
<iframe width="1280" height="720" src="http://www.youtube.com/embed/ot141OeFZRw?rel=0" frameborder="0" allowfullscreen></iframe>
...and a link to both the White 73' RSR and the Brown 74' RSR
Flieger 02-21-2012 07:58 PM
Will there be any actual racing/laps driven in anger or just the studio shots and the staged drive-by/car-to-car shots?
ajserrano 02-21-2012 10:33 PM
I haven't seen the entire DVD yet, but I do know Derek Bell and several other well known figures narrate the history of the 911 RSR. From what I saw, it was very well done and captivating, I'll have to check on the release, maybe it already has...
http://forums.pelicanparts.com/uploa...1330113112.jpg
ajserrano 02-24-2012 08:39 AM
The GT Rally Parking Brake Fabrication Photo Sequence
The 18th place #93 914-6 of Simonis-Hoier allows the 4th place Alfa Romeo T33-3 of de Adamich-Pescarolo to pass at the ADAC 1000 Kms of the Norburgring (1971)
http://forums.pelicanparts.com/uploa...1330113715.jpg
I know, I know, way too many pictures (over 140+!), but I wanted to really show the steps we took to achieve these results. Like no other, one-of-a-kind...
http://forums.pelicanparts.com/uploa...1330104447.jpg
http://forums.pelicanparts.com/uploa...1330104876.jpg
http://forums.pelicanparts.com/uploa...1330104890.jpg
http://forums.pelicanparts.com/uploa...1330104902.jpg
http://forums.pelicanparts.com/uploa...1330104916.jpg
http://forums.pelicanparts.com/uploa...1330104928.jpg
http://forums.pelicanparts.com/uploa...1330104941.jpg
http://forums.pelicanparts.com/uploa...1330104958.jpg
http://forums.pelicanparts.com/uploa...1330104973.jpg
ajserrano 02-24-2012 08:49 AM
Cont...
This is one of several photos I received from Mr. Mark T. Russell. Here is what Mark Rusell had to say...
Armando, Here are some pictures of a 914/6 GT that my brother raced in 1971. In Daytona the #19 car was driven by Steve Behr, John Buffum and Irwin Kremer.
It finished 8th over all and 2nd in GT. It was a two car effort. The #18 car was not a factory GT car. They ran at Sebring March of 71 now #29 but did not finish.
There it was, driven by Charles (Pete) Conrad with Behr and Buffum. Pete Conrad commanded Apollo 12 and was the 3rd man to walk on the moon.
http://forums.pelicanparts.com/uploa...1330113923.jpg
With these many detailed photos, anyone can certainly try and give this modification a try. I find the photos extremely helpful...
http://forums.pelicanparts.com/uploa...1330105185.jpg
http://forums.pelicanparts.com/uploa...1330105197.jpg
http://forums.pelicanparts.com/uploa...1330105208.jpg
http://forums.pelicanparts.com/uploa...1330105219.jpg
http://forums.pelicanparts.com/uploa...1330105231.jpg
Pilot hole being drilled...
http://forums.pelicanparts.com/uploa...1330105247.jpg
Drilling to final i.d.
http://forums.pelicanparts.com/uploa...1330105265.jpg
...and the other side.
http://forums.pelicanparts.com/uploa...1330105280.jpg
De-burring and prepping the drilled surfaces
http://forums.pelicanparts.com/uploa...1330105295.jpg
ajserrano 02-24-2012 08:55 AM
Cont....
http://forums.pelicanparts.com/uploa...1330114519.jpg
http://forums.pelicanparts.com/uploa...1330105952.jpg
http://forums.pelicanparts.com/uploa...1330105968.jpg
http://forums.pelicanparts.com/uploa...1330105982.jpg
http://forums.pelicanparts.com/uploa...1330106001.jpg
http://forums.pelicanparts.com/uploa...1330106029.jpg
http://forums.pelicanparts.com/uploa...1330106048.jpg
http://forums.pelicanparts.com/uploa...1330106068.jpg
http://forums.pelicanparts.com/uploa...1330106084.jpg
http://forums.pelicanparts.com/uploa...1330106105.jpg
ajserrano 02-24-2012 09:01 AM
Cont...
Here is a photo from Wilfried Geerts he sent me in December, 2004. Subject: 914/6 GT at Spa 1971
Hello, VERY NICE your 914-6 GT site! As a real Porsche lover, I can only say "SUPERRRRRRRR". I love the Porsches prior to 1974, and most of all, the 911 GR4 and RS, RSR cars!
I have a lot of pictures in my collection and I sending you a never published picture taken at the 1971 Spa (1000 km) event.
Regards from Belgium! Belgianporschist,
Wilfried
(also a Vic Elford fan!)
http://forums.pelicanparts.com/uploa...1330114983.jpg
http://forums.pelicanparts.com/uploa...1330106330.jpg
http://forums.pelicanparts.com/uploa...1330106345.jpg
http://forums.pelicanparts.com/uploa...1330106357.jpg
http://forums.pelicanparts.com/uploa...1330106371.jpg
http://forums.pelicanparts.com/uploa...1330106388.jpg
http://forums.pelicanparts.com/uploa...1330106403.jpg
http://forums.pelicanparts.com/uploa...1330106423.jpg
http://forums.pelicanparts.com/uploa...1330106438.jpg
http://forums.pelicanparts.com/uploa...1330106456.jpg
carr914 02-24-2012 09:02 AM
Armando, quite a lot of work - wow
I put a note on my GT on your site that it is For Sale - need to fund my Racing
T.C.
