How to remove heater control box/blowers?
The Haynes book is a little vague about the actual removal of these parts.
I've got the fuel tank out, all the ducting hoses are removed, and control cables are loose. I have also removed the bolts from inside the cabin, on the top of the firewall that holds the "boxes" in place. They are loose, and I can move them a little, but just not quite enough to pop them out. Do I have to remove the dash so the defrost vents can have more room to move? Is there something else I'm missing? |
Rookie
IIRC there are two bolts on the sides too. Those have to come out.
It's a bear to remove. That I remember vividly. |
Got it, thanks.
I missed a couple spring clips on the front and back of the units. |
Thread Tools | |
Rate This Thread | |
