Busted!
R there any 4 to 5 Lug adapters so I can put on Chevy rimz?
I gotta 914 project thats gittin a corvette motor conversion an flairs instaled so I can fit some 22" Rimz. Gotta put all dat power down on tha street! Tha flairs R done but I gotta work on fittin tha lambo doorz.
Problem iz tho...tha lugs R 4 bolt an the Rimz that I wanna git R off a 5 lug '03 Impala. Do they make a adapter so I can run Chevy Rimz? ![]()
Playa Sez: Check out my homes rimz video: http://forums.pelicanparts.com/off-topic-discussions/571869-look-em-big-ol-rimz.html Free Healthcare 4 All:http://www.youthnoise.com/page.php?page_id=2867 Free Collage Education 4All: Last edited by Playa76911S; 05-03-2013 at 09:57 AM.. |
Fleabit peanut monkey
Doors look fine. Perhaps you are being too fussy?
Edit: I also see at least five holes in that fancy wheel.
1981 911SC Targa Last edited by Bob Kontak; 05-03-2013 at 11:31 AM.. |
Administrator
I don't believe anyone does. Definitely not ones I would ever use, at least.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Good luck with that project....playa. The lambo doors are the way to go if you are a real deal baller.
'71 914-6 #0372 '17 Macan GTS |
Since your putting a Chevy motor in it, you should stick with that El Camino look in the rear trunk area.
He could hinge the rear light bracket for a tailgate.
1981 911SC Targa |
ASE Master Tech - 35 yrs
just search eBay with 4x"target size" - lots of high quality adapters out there and they are used by hotrodders all the time - just don't plan to race on them unless they are steel instead of alum - ther is a guy in SoCal who makes steel adapts - expensive
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
What do you need adapters for, fer heavnz sake, just crazy glue the rims to the rotors. But you need to put on a 15" lift kit first.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
