Got a question. I was told that if I put spacers in the original 914 calipers I can put 911 rotors in the back and still have an E brake. Has anyone done this? Does anyone know of someone making spacers for the 914 calipers??? If so, you can contact me here or email me at frankiec@outrageous.net Any info would be greatly appreciated.
Thanks for your help.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-03-2013, 10:09 AM
Nick at Pelican Parts's Avatar
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
914 Geek
Evidently this is quite possible. For instance, see the following thread:
914-6 Brake up grade
--DD
Old 07-03-2013, 03:55 PM
Resident Electrician
Mike Bellis's Avatar
Call Eric at PMB Performance...
PMB Performance: We Don't Rebuild Your Brakes... We Restore Them
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 07-03-2013, 08:29 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Smile Yes
yes - the factory did it for the 914-6 GT's - my car has them oem from Zuffenhausen
assuming you are using 914-6 calipers - you just have to get the spacer that was used on 911E's of the period
if you are talking 4-cyl caliper you'll have to mfgr them, but can use the E part as an example
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 07-07-2013, 10:33 AM
I have this setup on one my cars.Its nice to have the Fuchs but you lose 3cm of fender clearance per spacer thickness limiting you to 195 tires even with a bit of fender rolling.rather have 4 lug with 205s.kinda makes it a cosmetic thing and that **** ain't right(just kidding its your car and do what makes you happy)then again it's a moot point if you got gt flares.
chris
Old 08-08-2013, 03:01 PM
