Need help with ignition switch problem
When starting my '70 914-4 the key does not return by itself when released. It must be manually turned back to the "run" position. I assume there is a broken return spring someplace. My question is, do I need to replace the electrical switch or the keyed lock portion to solve the problem?
Old 08-31-2002, 04:11 PM
philinjax's Avatar
You need to replace the key lock (mechanical section) of the switch. While your at it, replace the electrical too.
Phil
Old 08-31-2002, 04:29 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
On a 70-71, the electrical section is a bit of a PITA to replace. Not even sure if it is still available... If it is, you have to splice the wires or remove them from the connector on the body one-by-one. No easy plug like the later ones...
--DD
Old 08-31-2002, 08:04 PM
