Monday (guest)
Guest
Posts: n/a
Hey I'm installing a rear shift trans in my 69 bug what's the way you would hook up the shifter rod can I cut where it connects to the rod and move it to the top I alreDy flipped the hub
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-18-2014, 08:18 AM
Nick at Pelican Parts's Avatar
I haven't done this procedure. SO I can't be of much help I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
914 Geek
The easiest thing to do would be to find a nose-cone and selector from an early 911 or 912 gearbox. Those are more or less the same as the 914 box, but do not have the mounting ears (which may need to be cut off to fit in the Bug chassis anyway) and have the selector coming straight out the front, rather than out of the side like the 914 box does.
--DD
Old 05-18-2014, 09:44 AM
You REALLY need to clarify what you have, what you've done and what you want to do. Having done this sort of thing, I may be able to help you. What "hub"?
The Cap'n
Old 05-18-2014, 01:49 PM
porschetub's Avatar
I think the OP means he has flipped the diff from one side to the other.....kinda hope its set up right.
Wouldn't the tailshift box be better in this application,certainly would be easier to get the shift working nicely,I have seen an article on this and it used a 911 box.
The sheetmetal around the rear torsion bar tube needs a lot of cutting to get the box forward enough to get cv shaft alignment etc.
IMO a vw irs 4/speed with the right ratio's is a much cheaper/easier option or there is the 5/speed T25 box.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 05-21-2014, 11:35 AM
