Question Drop 914-6 eng. to do valve adjustment?
I'm debating on having a large RAT motor built or going for 911 six cylinder conversion. And was wondering if you had to drop the six every time to do a valve adjustment. Plus you have to check the valve timing (cam sprockets) at the same time, right? I'm just looking at the Pros & cons of 4 cyl. vs. 6 cyl. Thanks for any info or input.
Ralph Gosnell
74 2.0 Slooooowly working on
Old 09-28-2002, 05:11 PM
Jim Smolka's Avatar
Assuming you have the 930 lower valve covers, and some of the Alum metal has been removed from them, you can remove adj the valves w/o taking the motor out.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 09-28-2002, 05:42 PM
914 Geek
The cam timing is done only when you have had to remove the camshafts from the engine for some reason.
--DD
Old 09-29-2002, 05:43 PM
Grinding or sanding off the tops of the "ribs" (just on the top rear corner on each cover, actually) on the lower valve covers (assuming they are the "turbo" aka 930 covers) will give you the clearance you need to get the lower covers off without otherwise disturbing the engine. Pretty standard practice for sixes in teeners, which I learned only recently.
ALSO, when you're building your six, keep in mind you will be wanting to get at the upper valve covers and what's under them, so route your hoses, fuel filters, wiring, etc etc accordingly.
John
Yellow '76 914 3.2
(YPAF)
Old 09-29-2002, 07:47 PM
scg scg is offline
scg's Avatar
I second that. It's easy on the left side (especially if you ditch the relay board); harder on the right side (battery).
I'm particularly glad that the fan rotates in the direction it does, since I stuck my hand in there when I got distracted while setting the timing -- no blood, no foul -- just glad it was at idle and not 3k or 6k rpm!
Scott
74 914-6 2.7
Old 09-30-2002, 06:01 PM
I know which one I would use...Thats for sure!!
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 10-01-2002, 07:29 AM
