"Rust Not, Rust Converter" stuff
Started my annual battery tray sanding/painting thing this morning.
Came across this "rust converter"stuff at my flaps. Doesn't say what's in it-not that it'd matter since I barely passed hi-sch chemistry two lifetimes ago.
Anybody know if it is any good? It states that it " stops rust on contact and converts it to an iron-hard paintable surface."
In any event, Happy Holidays to all ! // econo
Old 12-21-2002, 11:58 AM
I've used some stuff call "Right Stuff" wich is supposedly similar to OSPORO. I think it's mostly phosphoric acid. a pretty thin green liquid. seems to do ok. turns rusty stuff black.
Old 12-21-2002, 02:18 PM
Zeke's Avatar
Most rust correction products contain Phosphoric acid. Does exactly what the label describes. You only need to remove scale so the acid reaches the base metal. The more work you do the better, it can't do it all by itself. If you do this every year as you say, I see good things happening here. Why not get an Optima or other sealed battery when the time comes?
Old 12-21-2002, 02:20 PM
I use a spray gun with my air compressor and spray the stuff inside my wheel wells, under the car and around the rockers. Time will tell if it works or not.
Old 12-21-2002, 04:01 PM
i use a similar product that goes by the trade name "mar-hyde". after applying you still need to finnish the treated surface.great stuff.
kevin
Old 12-22-2002, 06:33 AM
I read the thread about a week ago re: Optima batteries. I plan to buy one in the spring to get by this annual problem. Thanks.
Old 12-22-2002, 06:36 AM
