Bay Area Patriot
converting early model car to a late model fuel rail
I don't know if you have followed my posts on Rennlist, but I have been searching for ways to get the little power I can out of 944 NAs. I have turned to an idea that would allow early cars to support adjustable fuel pressure regulators. unfortunately the early model fuel rail is uncompatible with adjustable FPRs you see in Porsche catalogs.
Therefore, I'm pursuing a late model fuel rail conversion accompanied by an adjustable FPR to see what I can do. At the moment I currently have a bad FPR that is causing a slight surge in lower RPMs along with reduced mid-range. But replacing the fuel rail is not what I just have in mind.....injectors as well. Which leads me to these questions. If anyone has done a conversion yet or has removed the fuel rails off both types of 944s, would extensions to the fuel lines on the early cars have to be made or would they just attach right up to the damper and regulator? Also, would I have to upgrade to later model injectors as well as a newer Motronic unit??? I have been told to get a Mass Airflow Sensor for my na, but i think thats a little overkill for now. Until I build a 2.7 stroker motor I won't consider it unless its a last resort for economy and performance and legality in California emissions.
Andy 1987 928 S4 - 3" Single Exhaust after cats 1999 Mercedes C280 Sport Package 2003 Mercedes ML350 |
Bay Area Patriot
bueller??? bueller???
suck my tail pipe
always something aint it?.. not enough power, not loud enough.. is anyhing else lacking in the Not good enough category?
My car is naughty |
I would say that "its probably not big enough." If you know what I mean.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
If you are looling for a late model fuel rail I gave one to Gordon. He would gladly exchange it for your early one as his has a very minor leak in his. Who ever had the car before tried to braze the crack and it's 99.99 percent sealed. Just weaps a little.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Bay Area Patriot
ehhhhhhh i don't think so... I seen enough 944s on fire on the track here during autocrossing to consider a fuel rail with a pinhole sized leak in it....
![]() I just wanna know if I can do it or not, yes, no, and what does it involve.
