AFJuvat's Avatar
Headscratcher Part 3 - Guess the problem
87 944 NA, 97000 miles.
Owner replaced headgasket, retensioned belts, etc. Head machined to spec. Water pump replaced as well
Leaking oil at the headgasket., small leak at waterpump gasket
Inspection indicates gasket was installed properly, no sealants were used, no physical failure of the gasket or head
No obvious defects in waterpump, OE gasket installed, no physical damage.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-01-2003, 08:34 PM
coupe's Avatar
Leaking oil at head gasket
Possible worn out piston rings.
Leaking water pump, perhaps partly blocked cooling system, causing excess pressure, allowing pump to leak.
Just a guess.
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 03-01-2003, 08:43 PM
Blackfoot's Avatar
cracked block?
Old 03-01-2003, 09:29 PM
afx afx is offline
afx's Avatar
Send a message via ICQ to afx
I would guess a cracked block also. Where is the oil leaking out at the headgasket (which cylinder)?
85.5 Red 944
Http://members.rennlist.com/afx
Old 03-01-2003, 10:16 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Improper torque applied, improper torque on water pump, didn't bleed air out of coolant, hotspot caused head warpage. didn't hook up fans, overheating caused gasket failure. overtorque-ing on all the above. Wrong type coolant, phos. ate away the goodies. wrong sized belt on water pump pulley caused overheating. cracked stuff/housing/block/head. didn't use new nuts and washers with head.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 03-02-2003, 12:23 AM
AFJuvat's Avatar
heheh Todwic got it on his "shotgun" approach.
Overtorqued head and waterpump bolts.
When overtorqued, the studs will "pull" put of the case slightly, raising a small "mound" of metal around the stud, preventing a good seal.
AFJuvat
Old 03-02-2003, 09:15 AM
