Can you post pictures? Even if you are using the lower mark the OT mark will still line up perfectly...
1986 944 -Garnett w/Koni suspension 1987 924S -Red, 951 Swapped, ~300hp 1987 924S -Red, project car 1987 924S -White, Project car 1988 924S- Red, Bone stock, Daily driver |
I tried posting pictures but doesn't work, can someone tell me how?
Wondering if the belt is not right honestly but that's the second one from the dealership, and I haven't seen anyone say anything belt related... cause I'm literally off by half a tooth, and that can't be, even if I messed up a sequence it should at least throw me off by a tooth..
Just thinking out loud
Are you using a gates belt? I've encountered a problem before with gates, doesn't line up.
83 944 91 FJ80 84 Ram Charger (now gone) |
Yes, porsche gave me a gates belt, I do have the first belt I got from napa that I could try on again..
What belt did you use, maybe I'll give that a try
You found the problem. Contitech.
Nooo wayyyy that's the problem whattt!!!
Wich belt should I get ?
Contitech, but doesn't the Contitech come with different pulleys than the stock ones on, and isn't their belt fitted for their upgraded pulleys
Can you send me a link to wich belt I need to specifically get
It's OEM. WFT more could you ask for? What year do you have?
1984 944 na
I mean I figured the dealership would at least give me the right one
Go contitech. Dealer doesn't stock parts for 30 year old cars, they supply (if at all) with aftermarket.
Edit. They do stock OEM parts, but we are concerned with a rubber belt.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 09-30-2018 at 12:25 AM.. |
Will do that, can you please send me a link to the exact one I need
Just cause I want to make sure I don't need the Contitech full kit, and can just use the belt on my stock pulley, cause I heard that could make a difference also, you know better
This one, https://www.pelicanparts.com/catalog/SuperCat/944M/POR_944M_BASFLT_pg4.htm#item13
Sorry, it's this one Part #: 944-105-157-04-M21
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 09-30-2018 at 12:35 AM.. |
Ah, yeah I just checked the PET so engines M44.01-02 (1982-1985.1) have flywheel number 944 102 051 00, while M44.05-09 (1985.5-1988) have 944 102 051 01. I have an 85.5 and 86 here and I didn't remember seeing that mark, but just went out to check two '86 engines that I have on stands that had it too. So I just missed it, I mostly just go by the OT mark anyway. That said, his '84 won't have the notch since it should have the early flywheel. Thanks!
1986 944 -Garnett w/Koni suspension 1987 924S -Red, 951 Swapped, ~300hp 1987 924S -Red, project car 1987 924S -White, Project car 1988 924S- Red, Bone stock, Daily driver Last edited by edredas; 09-30-2018 at 11:44 PM.. |
