Zombie
No-Start Related To Factory Alarm Issue?
Have reconnected my battery and have a no-start as earlier described...and am just wondering if this is related to the factory alarm system.
I know that the the P.O. replaced the battery within the last year, but I don't know the status of the factory alarm system. Is it possible that the alarm system was not properly disabled before the battery was replaced? Later I will check the alarm module as per the Clarks Garage writeup, but in the meantime any extra perspective on this would be great. Thanks! |
Have you tried plugging in a jumper wire to the fuel pump relay connections to make sure the pump runs? You'll be able to hear it. Have you tried testing for a spark? You should be able to get a spark tester at your local auto parts place. That will eliminate a lot of stuff from your testing. |
