Which floormat shape is correct?
My recently purchased '84 came with some nice thick black floormats with "944" in white print. There is not a label that I can see but they seem to be good quality.
I removed the drivers side, though, because there is a flap of carpet that extends from the front and covers the deadpedal / footrest on the left-most side and this was secured by velcro, which did not seem correct.
It looks like most images I can find of 944 mats don't have this "flap" but some do have the flap. Are both designs correct?
Old 12-12-2019, 04:57 AM
here are the two designs I've seen
Is this a matter of personal preference or is one correct for a certain range of model years?
Old 12-12-2019, 05:08 AM
The flap was designed to cover the dead pedal area, but turned out to be problematic, so later designs left the flap off.
Good luck, George Beuselinck
Old 12-12-2019, 05:29 AM
The tan drivers mat doesn't look correct where it goes under the drivers seat where it needs to go around the seat rails.
Old 12-12-2019, 03:44 PM
Misunderstood User
I had the ones on the left for a very long time - George is correct aboutthe flap for the dead pedal. If not secured, the flap folds over.
I'm using aluminum diamond plate - I used a cardboard template and custom made the mat. I have a rubber edge around the perimieter so it doesn't cut the floor carpet. The mat doesn't move. My only problem is I should have clear coated the mat after I painted them flat black. Over time, the paint chips off.For the dead pedal, I have a Renline plate the wraps around the dead pedal. It is secured with (2) screws.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 12-13-2019, 03:03 AM
racer's Avatar
Also note the years.
1985 had two versions.. 1985 and 1985.5 - This was when Porsche most notably changed the dash. A side effect likely was a change in seats/ seat rails as they were trying to improve room for the driver. Could be why the two mats look different where they go under the seat, as well as the "dead pedal" flap.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 12-13-2019, 04:29 AM
