Send a message via ICQ to Dinhster
Can't get into gear, Please HELP
Something wierd happened. I can't get my 86'951 into gear. It will pop into gear fine when the engine is off, but not when on. It happened once before, about a month or so earlier. I didn't think anything about it. Otherwise she felt fine, no odd behavior until now. I drive kinda hard. I hope I didn't break anything. She's got 98K on her with 30K on the clutch. My manual is in storage until I dig them out.
Any ideas? Thanks.
Old 06-23-2000, 07:03 PM
stray15's Avatar
Send a message via AIM to stray15
Check out my post: Major clutch problem, please help. Tell me if any of this is like your problem.
'83 944
Tim
Old 06-24-2000, 06:29 AM
Could be a leaking clutch slave cylinder
Old 06-26-2000, 10:52 PM
How do you mean? Or how do I check it out? There's no leaking outside the car...
Old 06-27-2000, 06:25 PM
I once had a defective clutch slave cylinder, there was no leaking noticable from outside the car, but every time I got in the car after it sat for a while I would have to pump the clutch a few times in order to get it to work, and get the car into gear.
Unfortunatley I didn't do the work myself so I can't really advise you on what to look for, I only know the symptoms.
Perhaps 1.2Gees can advise you on where to look.
Old 06-27-2000, 08:50 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Hmm
I would think
tweeks.com
**********.com
or if you want to go used,
Pelican parts, or
foreignintrigue.com
should be amond the better suppliers, and Pelican parts is a good one too, with excellent instructions (and tech articles).
Good luck,
Ahmet
It's all the driver...
Old 06-27-2000, 08:53 PM
