Driver side low beam Headlamp issues
I replaced the lamp with a new one and the issue persists. I get bright lights for both driver and passenger but I only have passenger side low beams.
Fuses look good and I dont see how it could be an issue with the relay. Contact points look clean but I scraped with a razor to be sure. Any suggestions would be greatly appreciated. |
944 addict
I'd check the ground connection to the body/frame. It's in the area near the a/c dryer, behind the driver's side headlight.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Patrick
Or, in my case, the culprit was the connector pin behind the relay/fuse board.
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
