Balance sahft axial end play 1/8". woodruff key doesn't sit properly.
Merry Xmas, guys.
Upper Balance shaft has an axial end play of about 1/8" and keyway is not fully "exposed" and woodruff key doesn't sit properly.
Is there any way to hold shaft from spinning and driving spacer sleeve in some more? Sprocket won't slide in, because of key sticking out too much.
see picture and video.
video - https://youtu.be/tlqARiUm6jM
Old 12-25-2021, 06:39 PM
...done....
Old 12-25-2021, 08:20 PM
Does “done” mean you’ve solved your problem?
John
82 911SC coupe
Old 12-26-2021, 08:00 AM
John,
Yes, I solved this "problem" - locked shaft and drove sleeve in to give enough room for woodruff key, the axial end play is minimal - about 1/16", now and key sits properly.
Old 12-29-2021, 04:53 PM
*** correction ***
axial end play is less than 1/32" - there's barely any play.
shaft rotates normally without binding (rotated by hand).
Old 12-29-2021, 05:35 PM
Tags
balance shaft , end play , key , play , woodruff
