Engine block coolant drain
I have seen 2 pictures of it and descriptions and I look where it says and where the picture shows me and I just can't find it. Can someone tell me exactly where the block coolant drain is.
Thanks |
The block coolant drain is located on the passenger side of the engine approximatly 1 to 2 inches above the joint between the pan and the block at the #4 cyl. It is a bolt that I think uses either a 13 mm or 15 mm socket.
Terry R. 1988 944 NA AT Alpine White 1987 944 NA AT Stone Grey 1987 944 NA 5 Speed Stone Grey 1987 944 S 5 Speed Triple Black |
The easiest way to drain the block is to remove the plastic adaptor on the water pump (ok, you will need a new o-ring) or if you have a late enough 944, disconnect the hose off the adaptor. This will drain the block, jack the back of the car up a bit to fully empty. This eliminates the "damm, the block threads are stripped" scenario.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
