Luis de Prat's Avatar
What size Allen key to remove late power seats?
Subject says it all. I must remove the seats in my late 951 to replace a bad power switch and would like to know what size Allen key I'll be needing.
I understand it's quite easy to strip these bolts, too.
Old 06-19-2003, 08:46 AM
Send a message via AIM to IBRJA
The proper wrench is in your tool kit that came with your car.
Old 06-19-2003, 12:33 PM
AFJuvat's Avatar
But since most cars today don't have toolkits... (where do all those tool kits go anyways??)
believe (95% sure) it is a 6mm, could be an 8mm Ball ended-hex wrenches are your friend geting the bolts out
Your Mileage may vary if someone has replaced them with a non-standard bolt
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-19-2003, 08:15 PM
Come to think of it, I do have that funny shaped allen wrench and didn't know what it was for!
Thanks guys.
Old 06-20-2003, 03:06 AM
Just an update on my power switch replacement. The driver seat was stuck over the seat rail allen bolts and would not slide back due to the broken switch, so the bolts were basically inaccessible.
One thing to note if this happens to anyone: the seat rails have a hole on the top side about a palm's breadth from the front of each rail. I took a leap of faith and slid the seat farther forward until the holes were directly above the allen bolts and was able to undo them.
If I hadn't been able to, the car would have been undriveable because the seat bench was literally below the dashboard... All's well that ends well, but I thought I'd pass this tip along in case it happens to anyone.
Old 08-04-2003, 09:14 AM
