Compression gauge test
1984 auto
Hi, At last I bought a compression gauge tool. Today I made my first diagnostic then please help me to know if I did something wrong. I took out the spark plugs and I disconnected the coil. I connect the tool to piston 1 then to the others, then I repeat, later I insert 9 ml of oil to piston 1 and I connect again the tool, the to the other. Obvious I did the test at wide open body throttle Ok, I have this readings 1.- 165 2.- 167 3.- 150 4.- 160 with oil 1.- 210 2.- 205 3.- 200 4.- 205 I supose that this are bad news ! I recently replaced the head gasket and valves then I need first overbore rings ? Let me know regards |
what is the correct compression presure ?
what is the cr of the engine ?, I believe 10.25 1 if a healthy engine should produce compression that is 18-19 times the compression ratio then 10.25 x 19 = 194.75 ? let me know |
Compression on a NA should fall between 171 and 180 PSI on a good engine.
Your numbers are looking a little on the low side for #3. Based on your with\without oil numbers, it looks like #3 has some rings that are on the way out. THe other numbers are consistant with a 19 year old engine. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Thanks afjuvat
reading another compression posts, I saw that I did some things the wrong way. 1. I did not disconnected the fuel relay 2.- I did not take out the air filter 3.- I did the test in a cold engine Do I need to do it again ? |
I don't recall where, but in the last couple of days I ran across a web site that said the minimum COLD compression was 145 psi. This would put your #3 cylinder close to the lower limit.
Cliff Hipsher '87 944 India Red '86 951 Kalahari Metallic |
I was using a compress checker and it said for my car it should be around 145 or within 10% of that. Mine came up as between 150-152.
-2002.5 GTI VR6 24V 6SPD -Kalahari Beige 89 Porsche 944S2 -87 VW GTI 1.8 16v -2007 Ford PIMP(free)star ...company car.... -1999.5 Jetta VR6 |
