Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Compression gauge test
1984 auto
Hi,
At last I bought a compression gauge tool.
Today I made my first diagnostic then please help me to know if I did something wrong.
I took out the spark plugs and I disconnected the coil.
I connect the tool to piston 1 then to the others, then I repeat,
later I insert 9 ml of oil to piston 1 and I connect again the tool, the to the other.
Obvious I did the test at wide open body throttle
Ok, I have this readings
1.- 165
2.- 167
3.- 150
4.- 160
with oil
1.- 210
2.- 205
3.- 200
4.- 205
I supose that this are bad news !
I recently replaced the head gasket and valves then I need first overbore rings ?
Let me know
regards
Old 07-03-2003, 10:22 AM
what is the correct compression presure ?
what is the cr of the engine ?, I believe 10.25 1
if a healthy engine should produce compression that is 18-19 times the compression ratio
then 10.25 x 19 = 194.75 ?
let me know
Old 07-03-2003, 10:33 AM
AFJuvat's Avatar
Compression on a NA should fall between 171 and 180 PSI on a good engine.
Your numbers are looking a little on the low side for #3. Based on your with\without oil numbers, it looks like #3 has some rings that are on the way out.
THe other numbers are consistant with a 19 year old engine.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-03-2003, 10:52 AM
Thanks afjuvat
reading another compression posts, I saw that I did some things the wrong way.
1. I did not disconnected the fuel relay
2.- I did not take out the air filter
3.- I did the test in a cold engine
Do I need to do it again ?
Old 07-03-2003, 11:02 AM
I don't recall where, but in the last couple of days I ran across a web site that said the minimum COLD compression was 145 psi. This would put your #3 cylinder close to the lower limit.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 07-11-2003, 08:50 AM
Send a message via AIM to TheCooler
I was using a compress checker and it said for my car it should be around 145 or within 10% of that. Mine came up as between 150-152.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 07-11-2003, 12:50 PM
