5 digit odo's were common up through mid 1980's
Porsche changed them over on the 944 starting with series 2 (85.5+) 911\930 have always had the 6 digit odos AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
OK. Will the 911/930 speedo fit in the early 944's so I can get six digits? Guess I might loose the GPM gauge.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
vott does ziss do?
would it matter considering that the mileage won't match anymore anyway?
Nope AFJuvat
vott does ziss do?
it would if you tried hard enough
vott does ziss do?
or pried, for that matter
If the guts are the same then it could be a transplant.
vott does ziss do?
So, just checking. You'd like to have a working odo again and decided that you want a six digit instead of five? Personally, I'd stick with the original for, well, originality's sake. Unless it's your daily driver, you probably don't want to put too many miles on the car for it to be a concern anyway. Or am I misunderstanding what you want to do?
84 944 Non Alcoholic |
