TCMdocs944's Avatar
Unhappy Cam marks = tdc always???
Tuesday eve when I got the timing belt back on and adjusted I freaked out for a few minutes...
Found tdc at the flywheel.
It matched cam marks PERFECTLY
turned the crank a few times with no major resistance
lined up the cam mark..
COULDN'T FIND TDC ON THE FLYWHEEL.
turned cam 180deg and there it was!
freakin out freakin out freakin out freakin out
Turned the flywheel one complete revolution to find tdc again
looked at the cam marks and it was perfect!
Is this normal- please say yes
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 07-31-2003, 05:56 AM
This is normal, the cam turns at half crank speed.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-31-2003, 05:58 AM
TCMdocs944's Avatar
Wheeeewhhhh.
The confusion comes in when the manuals tell you to turn the crank two complete revolutions and check alignment.
Old 07-31-2003, 06:15 AM
If you turn the crank two revolutions the cam timing must be on the mark. Always rotate the crank twice after every adjustment.
Old 07-31-2003, 05:16 PM
