Tuesday eve when I got the timing belt back on and adjusted I freaked out for a few minutes...
Found tdc at the flywheel. It matched cam marks PERFECTLY turned the crank a few times with no major resistance lined up the cam mark.. COULDN'T FIND TDC ON THE FLYWHEEL. turned cam 180deg and there it was! freakin out freakin out freakin out freakin out Turned the flywheel one complete revolution to find tdc again looked at the cam marks and it was perfect! Is this normal- please say yes
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
This is normal, the cam turns at half crank speed.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Wheeeewhhhh.
The confusion comes in when the manuals tell you to turn the crank two complete revolutions and check alignment.
If you turn the crank two revolutions the cam timing must be on the mark. Always rotate the crank twice after every adjustment.
Thread Tools | |
Rate This Thread | |
