Send a message via Yahoo to clinton
Can you tell if my thermostat is in backwards
Can you take a look at http://www.orderdairy.com/porsche2 and tell if it is in backwards. its near the bottom of the page thanks.
Old 10-28-2003, 01:39 PM
Autobahn Garage
No It's in right. the spring should always be faceing the motor you did it correct
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 10-28-2003, 01:54 PM
looks correct to me.
Old 10-28-2003, 01:55 PM
thanks for looking . My car still gets hot and im not sure why it runs fine but gets half way to the red is this normal it seems to stay at the half way mark when warm. I have new updated water pump, new stat, the fan comes on,it is bleed. Mabye the radiator is cloged but when i pulled the plug it seemed to come out fast and clean no gunk.
Visit my site www.orderdairy.com/Porsche/
Old 10-28-2003, 02:07 PM
SoCal Driver's Avatar
Just half way to the red? Start screaming when it touches the red and keeps going.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-28-2003, 09:18 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
i had that problem. but my radiator was about 75% clogged. it really scares you when you drive down the road and a separate guages that goes past 280 is pegged!
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 10-28-2003, 09:43 PM
Does it loose coolant? do the fans operate correctly? do you have the correct pressure cap? can you hear bubbling in the expansion tank? as long as everything works correctly, nothing is wrong.
The gauge is only a guide, not really to be trusted.
Yes, you could also install a seperate mechnical gauge.
Check the radiator and make sure it has even temperature all across the core.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-28-2003, 10:10 PM
I can see bubbling up in the expansion tank but it only does it if i pull the cap off .You think the head gasket is shot or what would this mean.
Old 10-29-2003, 04:08 PM
No it means you released the pressure in the system. Unless you do the diagnosis work this is all guessing.
Old 10-29-2003, 04:10 PM
