speed sensors
Back to the cold weather firing problem. A bud told me that dirty speed sensors will prevent the engine from firing in cold weather. Has anyone had this happen?
CH |
true..
What are and where is the speed sensors ?
Thanks for your answers in my engine problems post, I need time to check all the hoses, I hope this weekend ? |
I just took mine out and mixed them up I noticed that their is a D stamped and a B stamped on the bell housing and little yellow stickers on the sensors that tell you which one they are.
Good luck to clean up will take bout 1/2 hour Matt |
what do the speed sensors do? Do they need cleaned from time to time? How do you know if they need claned, what are the symptons?
Back to the top - help.
We all know that there are two sensor that appear to be megnetic pick-up sensors. One should be reference to top dead center (TDC typical for #1 piston). What does the otherone do? They appear to work in tandem somehow. How does the DME use this signal to advance/retard the timing? Can anyone shed some more light on this subject? Thx |
