ch944's Avatar
speed sensors
Back to the cold weather firing problem. A bud told me that dirty speed sensors will prevent the engine from firing in cold weather. Has anyone had this happen?
CH
Old 12-03-2000, 01:54 PM
Send a message via ICQ to porscheboi928s/c944t/n
true..
Old 12-03-2000, 02:18 PM
Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
What are and where is the speed sensors ?
Thanks for your answers in my engine problems post, I need time to check all the hoses, I hope this weekend ?
Old 12-07-2000, 04:01 PM
lordgrommit's Avatar
I just took mine out and mixed them up I noticed that their is a D stamped and a B stamped on the bell housing and little yellow stickers on the sensors that tell you which one they are.
Good luck to clean up will take bout 1/2 hour
Matt
Old 12-12-2000, 02:06 AM
what do the speed sensors do? Do they need cleaned from time to time? How do you know if they need claned, what are the symptons?
Old 12-12-2000, 11:07 AM
3sonfather's Avatar
Post
Back to the top - help.
We all know that there are two sensor that appear to be megnetic pick-up sensors. One should be reference to top dead center (TDC typical for #1 piston).
What does the otherone do? They appear to work in tandem somehow.
How does the DME use this signal to advance/retard the timing?
Can anyone shed some more light on this subject?
Thx
Old 08-22-2001, 05:39 PM
