Sabyre's Avatar
$150 for a battery? Sam's Club has them for $38.
I paid $60 for my POS battery at Advanced Auto Parts/Parts America. Wal-mart/Sam's Club Didn't have the size I needed at the time. I got the same warranty for the same price but less CCA and RA.
$150... He may be reffering to an Optima application, however the do not manufacture a direct replacement. I was also looking for an Optima Deep Cycle application. The only thing that I have found available for such an application is an Optima Yellow Top (deep cycle) D34 with a kit from Performance Products to mount it side ways. Overall as much as I wanted one and even though you can mount one in basically any position, I opted out of "riging to fit" situations. Eventually Optima will make batteries for the european market and supply us with something that will fit.
They are nice batteries.
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Old 01-05-2004, 12:57 PM
entertaining the idea
UconnTim97's Avatar
Welcome to the board. It will all be worth it when the car is done....
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 01-05-2004, 02:37 PM
SoCal Driver's Avatar
All car batteries last from four to five years. I've found no difference in performance between a $30 battery and a $150. Then I'm not running 10,000 amps of sub woofers either.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-05-2004, 04:03 PM
vott does ziss do?
ronin's Avatar
one word, Interstate. am on my third in nine years. the first was a five year that was from the P/O dating to 90, replaced in 96. the second was a five-year that lasted for seven. just replaced two weeks ago with a 72
Old 01-05-2004, 05:43 PM
AFJuvat's Avatar
Re: Needing all the help I can get! Everyone and anyone that knows about the 924S, READ!!
Originally posted by 924S1987
- Replace water pump and gasket : $260
- Replace belts :
- Replace head gasket : $100 for head set of gaskets
- Replace hood cable
- Replace battery : $140
- Replace brakes and brake pads
- Replace tires
- Drain and flush engine tranny
- Clean all grounds parts and sensors
- New distributor cap, ignition rotor, spark plugs, and ignition wires
- New vacuum hoses and tubes
- Replace pullys
- Change oil, oil filter
- Change air filter : $45
- Drain fuel
- Replace fuel filter : $25
- Replace brake fluid : $15
- Check Oxygen sensor
- Replace oil seals
You aren't off to a bad start.... lets see what we have here Your prices aren't bad for PARTS, but they neglect labor if you are going to have a shop do it.
- Replace belts : About $400 +\- $50 Parts\Labor
- Replace head gasket : $100 for head set of gaskets - NOT NECESSARY UNLESS IT IS LEAKING
- Replace hood cable $35
- Replace battery : $140 - Where do you shop, that is outrageous!
- Replace brakes and brake pads Pads and rotors will set you back around $400 - $500 for decent ones.
- Replace tires
- Drain and flush engine tranny -
- Clean all grounds parts and sensors - Clean the grounds, don't mess with the sensors, the connectors get brittle with age.
- New distributor cap, ignition rotor, spark plugs, and ignition wires - about $200
- New vacuum hoses and tubes - Just replace the rubber and plastic bits. To do it right, you will be pulling the intake manifold.
- Replace pullys - NOT NECESSARY
- Change oil, oil filter $20
- Change air filter : $15
- Drain fuel - Would replace the in-tank filter as well - runs about $53
- Replace oil seals: $100 for the seals.
Now - First priority (as has already been said) is belts - they need to be replaced before you do anything else. Until you know what you are doing, I do not recommend doing them yourself. Conversely, If you are doing your seals and waterpump, you should do those before you do the belts.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-05-2004, 06:03 PM
South Central Ohio? Wheres that? Is that anywhere close to Cincinnati or Mason?
86' Porsche 944 N/a
Old 01-05-2004, 06:53 PM
South Central is about 10 minutes west from Chillicothe, about 1 hour south of Columbus and 1 1/2 hour north of Cincy.
The first things I plan to do is replace head gaskets as well as other gaskets, check and replace the rubber parts because the rubber has probably rotten away to crap, drain all the fluids, replace the upper and lower hoses from the radiator, replace the filters, replace the belts and pullys.
THEN it should start and I can take it to a shop....right?
Old 01-06-2004, 11:04 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Skip the head gasket....Do the belts and seals first thing!! All the other stuff will fall after that is done. ie: the hoses have to come off to do the belt job..... Here is a picture of the area needing the seals and you will see the importance of replacing them now. For every shaft or roller there is going to be a seal....Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 01-06-2004, 11:14 AM
Ornery Bastard
You should not start the car until the belts have been changed.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 01-06-2004, 11:33 AM
I know the belts need changed, that was in my post when I asked if I did these things would it be okay to start?
Old 01-06-2004, 06:43 PM
What ever you do don't paint up the belts and pulleys. It doesn't help.
Old 01-06-2004, 07:03 PM
And only use NEW tensioners. And real oil filters are a good idea too.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-06-2004, 07:08 PM
vott does ziss do?
ronin's Avatar
but it looks so purposeful!
Old 01-06-2004, 07:10 PM
Sabyre's Avatar
If you do those things then yeah, it should be more than ready to start up.
Old 01-06-2004, 07:30 PM
Send a message via AIM to TheCooler
Whats with all the paint marks? LOL You only need what 3 marks and they are already there.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 01-07-2004, 03:04 AM
924Sman's Avatar
I copied this photo from another member. He did the marks. SoCal is up on this picture so he can tell you who is happy with the paint. Sman
Old 01-07-2004, 03:19 AM
Ornery Bastard
Sorry. I missed that, completely my fault.
This is one area where I really like my 914. The 914's camshaft is gear driven. All I have to worry about is adjusting solid lifters in a work area only slightly larger than your average mail slot.
Aaron
Old 01-07-2004, 05:13 PM
Chris_924s's Avatar
Aw hell- sell it and get a real Porsche..
(Wow that's a real departure from ME!)
Congrats on a fine automobile purchase- You'll never be sorry once you get the PM up to snuff. apart for the already stated dont forget to replace the fluids- brake fluid etc..
GAWD I love my car.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 01-08-2004, 10:55 AM
