LinkBack | Thread Tools | Rate Thread |
$150... He may be reffering to an Optima application, however the do not manufacture a direct replacement. I was also looking for an Optima Deep Cycle application. The only thing that I have found available for such an application is an Optima Yellow Top (deep cycle) D34 with a kit from Performance Products to mount it side ways. Overall as much as I wanted one and even though you can mount one in basically any position, I opted out of "riging to fit" situations. Eventually Optima will make batteries for the european market and supply us with something that will fit. They are nice batteries.
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka |
entertaining the idea
Welcome to the board. It will all be worth it when the car is done....
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
All car batteries last from four to five years. I've found no difference in performance between a $30 battery and a $150. Then I'm not running 10,000 amps of sub woofers either.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
vott does ziss do?
one word, Interstate. am on my third in nine years. the first was a five year that was from the P/O dating to 90, replaced in 96. the second was a five-year that lasted for seven. just replaced two weeks ago with a 72
Re: Needing all the help I can get! Everyone and anyone that knows about the 924S, READ!!
- Replace water pump and gasket : $260 - Replace belts : About $400 +\- $50 Parts\Labor - Replace head gasket : $100 for head set of gaskets - NOT NECESSARY UNLESS IT IS LEAKING - Replace hood cable $35 - Replace battery : $140 - Where do you shop, that is outrageous! - Replace brakes and brake pads Pads and rotors will set you back around $400 - $500 for decent ones. - Replace tires - Drain and flush engine tranny - - Clean all grounds parts and sensors - Clean the grounds, don't mess with the sensors, the connectors get brittle with age. - New distributor cap, ignition rotor, spark plugs, and ignition wires - about $200 - New vacuum hoses and tubes - Just replace the rubber and plastic bits. To do it right, you will be pulling the intake manifold. - Replace pullys - NOT NECESSARY - Change oil, oil filter $20 - Change air filter : $15 - Drain fuel - Would replace the in-tank filter as well - runs about $53 - Replace fuel filter : $25 - Replace brake fluid : $15 - Check Oxygen sensor - Replace oil seals: $100 for the seals. Now - First priority (as has already been said) is belts - they need to be replaced before you do anything else. Until you know what you are doing, I do not recommend doing them yourself. Conversely, If you are doing your seals and waterpump, you should do those before you do the belts. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
South Central Ohio? Wheres that? Is that anywhere close to Cincinnati or Mason?
86' Porsche 944 N/a |
South Central is about 10 minutes west from Chillicothe, about 1 hour south of Columbus and 1 1/2 hour north of Cincy.
The first things I plan to do is replace head gaskets as well as other gaskets, check and replace the rubber parts because the rubber has probably rotten away to crap, drain all the fluids, replace the upper and lower hoses from the radiator, replace the filters, replace the belts and pullys. THEN it should start and I can take it to a shop....right? |
Certified Rennwerker
Skip the head gasket....Do the belts and seals first thing!! All the other stuff will fall after that is done. ie: the hoses have to come off to do the belt job..... Here is a picture of the area needing the seals and you will see the importance of replacing them now. For every shaft or roller there is going to be a seal....Sman
PCA " I've been everywhere, done everything......just can't remember any of it!" ![]() |
Ornery Bastard
Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
I know the belts need changed, that was in my post when I asked if I did these things would it be okay to start?
What ever you do don't paint up the belts and pulleys. It doesn't help.
And only use NEW tensioners. And real oil filters are a good idea too.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
vott does ziss do?
but it looks so purposeful!
Whats with all the paint marks? LOL You only need what 3 marks and they are already there.
-2002.5 GTI VR6 24V 6SPD -Kalahari Beige 89 Porsche 944S2 -87 VW GTI 1.8 16v -2007 Ford PIMP(free)star ...company car.... -1999.5 Jetta VR6 |
I copied this photo from another member. He did the marks. SoCal is up on this picture so he can tell you who is happy with the paint. Sman
Ornery Bastard
This is one area where I really like my 914. The 914's camshaft is gear driven. All I have to worry about is adjusting solid lifters in a work area only slightly larger than your average mail slot. Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) Last edited by AaronM; 01-07-2004 at 04:16 PM.. |
Aw hell- sell it and get a real Porsche..
(Wow that's a real departure from ME!) Congrats on a fine automobile purchase- You'll never be sorry once you get the PM up to snuff. apart for the already stated dont forget to replace the fluids- brake fluid etc.. GAWD I love my car.
TENSION YOUR SOCKS! 88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING! 87 NA Diamond Blue Metallic ~ Gone |
Thread Tools | |
Rate This Thread | |
