fast924S's Avatar
Send a message via AIM to fast924S
Cam timming??
I hvae notice a couple of companies are selling adjustable cam gears for the 944/924S. I know adjustable cam gears dont make HP but the do move around the POWER CURVE. So I have a couple of questions for you guys.
1. How far can you advance or retard the Cam gear on the 944 series 2.5L engine before valves start to bend??
2. Has anyone done this to there P-car??
3. Do you think it would be worth it?? my power curve doesnt really start until 3,500rpm, It would be sweet to get it around 2,800 or 3,000 rpm
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-01-2004, 05:40 PM
AFJuvat's Avatar
About +\- 7.5 degrees.
Or about two teeth on the cam gear before you start bending valves.
The DME controls ignition timing by changing where the distributor fires in its car. (thats why the dizzy rotor is so wide)
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-01-2004, 05:57 PM
I can understand the benefits of being able to retime the cam due to the shaved head (thanks FR), but how would changing the cam timing (relative to the crank) improve the power curve? Especially with stock components?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 03-06-2004, 07:23 PM
