Porsche Crest problem with putting engine in
i am having trouble putting the engine in the drive shaft keeps getting in the way is there any way i can move it a little
Old 03-03-2004, 07:51 PM
AFJuvat's Avatar
THe transmission should be out already.
If it is, rotate the torque tube (drive shaft) 180 degrees and push it back further.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-03-2004, 08:53 PM
the transaxle is not out that is why i want to know how to take it out
Old 03-04-2004, 10:42 AM
Wolf1's Avatar
You may want to get a manual. The Haynes manuals are pretty cheap and easy to follow. It will save you some time and trouble.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 03-04-2004, 11:24 AM
SoCal Driver's Avatar
When putting an engine in from the top (or bottom) you have to use a hanger that lets you angle the engine. Up or down in front depending.
If you are putting it in from the top then the front of the engine has to be a bit up and angled to one side. The cross member has to be dropped off of the chassis. You can leave the struts connected at the top but the rear a-arm bushing and the sway bar hangers have to be disconnected.
It's advised to remove the fans from the radiator and possibly the power steering pulley from the crank.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
