Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
gasket for oil drain plug?
Just changed my oil today, found there was no gasket on the drain plug and *two* on the oil filter - ya think one of those might have been why it was leaking? anyway what is supposed to go on the drain plug? Copper washer? O-ring? I cut a piece of cardboard out of a box top to make my own gasket for now but next time I change the oil I'd like to do it right. Unfortunately there's no Porsche dealer nearby...
thanks,
nate
PS - picked up about half a bar of oil pressure after the change, PO must have taken it to Jiffy Lube or something and I bet they used 10W30... grr...
1988 944... and a bunch of other cars
Old 03-13-2004, 03:00 PM
CSU944's Avatar
It's an aluminum crush washer, you can get them cheap through Pelican Parts or elsewhere. Here's pelican's page:
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_oilsys_pg1.htm
Old 03-13-2004, 04:52 PM
Metal washer. problem is that it needs a 22mm I think at least on a 951. After driving all around I eventually found one at NAPA. I took the plug with me while I search through every washer box in town. The washer I used appered to me to be copper. I'm sure pelican sells these.
Old 03-13-2004, 04:54 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Regarding those little metal washers - I put one on the drain plug but didn't have one on the filter - is there supposed to be one there?
Black Cars Matter
Old 03-13-2004, 05:15 PM
Roger Hall's Avatar
No washer on the filter. The washers on the drain plug come in either aluminum or coper either is acceptable.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 03-13-2004, 07:47 PM
entertaining the idea
UconnTim97's Avatar
I got mine a here at Pelican..
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 03-13-2004, 11:09 PM
adrian jaye's Avatar
I think this depends on what model you have. PET, shows bolt and sealing washer, I think there are 2 gaskets from memory on oil filter
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 03-14-2004, 01:31 AM
Chris_924s's Avatar
FWIW possibly on the 16v's.. no idea.
I haven't ever seen a gasket on an oil filter.
'cept an old Nash..
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 03-14-2004, 09:22 AM
pokey's Avatar
Send a message via AIM to pokey
Go with the aluminum washer, disimilar metals are best kept to a minimum, they will corrode each other (galvanic cell), the copper corroding the aluminum, and cause the plug to sieze into the pan. all it takes is letting it get wet, that gives it the eletrolite to become a battery.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 03-14-2004, 11:03 AM
meister member
speedracing944's Avatar
They are $.25 a piece at pelican. I just purchased 4 of them.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-14-2004, 11:14 AM
I am changing the oil on my 89 944 S2. Regarding the drain plug washer, is it this part # 900.123.118.30 (22 x 27 mm), or do I need 900.123.049.30 (26 x 32 mm)?
Old 09-19-2011, 04:56 PM
ernie9944's Avatar
Originally Posted by jep32 View Post
I am changing the oil on my 89 944 S2. Regarding the drain plug washer, is it this part # 900.123.118.30 (22 x 27 mm), or do I need (900.123.049.30) (26 x 32 mm)?
You need #900-123-049-30 which is (22x27)
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 09-19-2011, 06:01 PM
