Custom User Title
rammstein's Avatar
speedometer needle
I did a search, and found nothing that could help me. I got my new odometer gear, and I'll be damned if I can't get the speedo needle off. I do not want to break anything, but it seems I will need some extra force. Any special recommendations? Should I try some penetrating oil?
Also- Can I fix the occasional "speedo sticking at zero for a moment" problem that I have while I'm in here?
Thanks in Advance, help me not wreck my car. ;P
Old 07-16-2004, 03:31 PM
Custom User Title
rammstein's Avatar
ok- the speedo needle is off now. BUt what the hell is the deal with these e-clips? Dammit, clarks garage says they are "easily removed". Mine are quite tenacious.
Old 07-16-2004, 05:05 PM
AFJuvat's Avatar
It just pulls off you have to get under it and pull it STRAIGHT (note emphasis).
It does require a little force.
Speedo sticking is usually electrical - clean up all of the connections.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-16-2004, 05:06 PM
Custom User Title
rammstein's Avatar
Giddyup! Its all back together. I had to clean everything. The old gear had disintegrated. I still don't get how the reset rod gets pulled (is the solonoid like a puller?), but I'll hopefully get it back in and report if I have been successful or not.
Thanks Juvy.
Old 07-16-2004, 06:03 PM
Send a message via AIM to bluebullet
the odometer is setup like a voicecoil....you give the bottom piece current and it pulls the magnet down, which resets your trip odo..i had mine apart today
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 07-30-2004, 11:27 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
To get the needle off, use two butter knives wrapped with a dish towel and put them under the center of the needle and twist.
For the e-clips, they are not "easily removed" use a pick or small screwdriver and do it on a big table where you can see where they fly
yes the reset thingy is pulled in like a starter solenoid.
good luck,
nate
1988 944... and a bunch of other cars
Old 07-31-2004, 08:15 AM
