Super Moderator
click sound from front shock area
when i make a sudden left turn and the front-passenger shock+wheel gets loaded i hear a single 'CLICK' sound. this doesn't happen when i make a sudden right turn.
i've tried parking the car and pushing down (and bouncing) the shock area but the noise doesn't occur. it seems it only occurs when making sudden left turns. any idea what this could be? thanks in advance.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
the bearing on the top of the strut will do this.
Bob S. former owner of a 1984 silver 944 |
mine does the same thing. Check out your motor mounts and swaybar bushings. I bet they're shot.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
Super Moderator
someone else was telling me it could be the ball joint. is that another possibility?
Super Moderator
okay i jacked up the car and got under it. found the problem is the inner sway bar bushing on the passenger side had deteriorated and fallen out. the clicking was caused by the sway bar rubbing/grinding against the metal clamp.
apparantly this is a common problem with 944's because of the location of the power steering reservoir, it leaks power steering fluid in that area which accelerates this problem.
suck my tail pipe
Ball joint would be my first guess and worst nightmare, if they snap.. you're ghost riding.
My car is naughty |
Also during an oil change, it's common to drip oil from the filter onto those, so I don' tknow if that would affect the wear on that bushing much. When you replace yours, take pics if you can
yaay for pictures
Super Moderator
ah yeah, the oil filter does lie directly above this area. i didn't take any photos (it's a pretty simple procedure) but i did learn that you have to remove the mounts on both sides of the swaybar in order to replace one side, because the whole thing is one solid piece of metal.
pelican does have a detail blowup diagram;
Super Moderator
btw, can anyone post a photo or a diagram of exactly where the ball joint is located and how to check if it's okay?
i know it's on the control arm, but where? also, i've read/heard that if the ball joint goes bad you'll have to replace the whole control arm (like $700 just for the part). is this true? why can't you just replace the ball joint?
On earlies, you can replace the abll joints separately, but on laters you have to replace the whole control arm.
http://www.connact.com/~kgross/FAQ/944faqca.html Quote:
