951 Machine Shop work?
With the engine out of the car, and my plans for a total rebuild underway what kind of machine work do I want to perform to the top and bottom end of the engine. I was planning on doing the bearings and rings, and of course sending the head off. What else should I have done while I have the engine out of the car?
Another question is what do I want to do about the turbo? Is there a preferred company around here who will do turbo rebuilds on a 951? Thanks again for all of the info! ~Eric
Eric Devansky 986s - Radio Flyer 20% of a 951 parts car remains |
Have the crank checked and micropolished. After that, other than having the head done, and having the cylinders measured, you should be all set.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Are you just doing the Basic rebuild or performance rebuild
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
I am going to rebuild the car to stock, however I would like to build the engine to handle a bigger turbo and some other goodies down the road.
~Eric
Why not get a mild port and polish and a good valve job, It would help your turbo spool faster
~Eric
damn, FR, that's a BFE!
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
Have the Crank Cross-drilled while you're at it. It's an easy way to avoid spinning a bearing. Here's some info Huntly Racing did on the subject:
http://forums.rennlist.com/rennforums/showthread.php?t=154715&highlight=cross+drilled
Ryan '84 944 moneysucker edition (SFR, Corbeaus, etc.) '02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's |
Exactly, cross-drill the crank. If you want, you could lighten it, would help the engine rev a bit quicker, but it will cause it to be a little unstable at idle. Just make sure that everything is checked out, and within tolerances. Hehe, FR that's that diesel engine for a tanker that was posted on here a while ago, isn't it? Oh man, a ladder going down into the crankcase by each cylinder, you know it's big when.....
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Uhmm I wonder what the tolerances for that engine are??? measured in inches of clearance?
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
knife-edge that tanker crank...and be able to pull a few thousand water skiers
Tom Early '85 944 |
Dog-faced pony soldier
I've seen that before; makes you wonder what a simple oil change costs now at $60 a barrel. . .
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
a crank that big isn't counterbalanced? (mind boggles)
nate
1988 944... and a bunch of other cars
